CD20 NISSAN PRIMERA DRIVE (TIMING) BELTS
Chilupula
Post by Chilupula »
CD20 DIESEL ENGINE VEHICLES SPARE PARTS
I am looking for a drive (timing) belt for my Nissan Primera car whose specifications are follows:
BELT SPECIFICATIONS
-Number of teeth - 111
-Length - 1057mm
-Width - 25mm
VEHICLE SPECIFICATIONS
-Engine - 2.0
-Engine type - CD20
-Model - primera (P10) hatchback
-Fuel type - Diesel
-VIN/CHASSIS - SJNFDAP10U0488327
-Year - 2000
Re: CD20 NISSAN PRIMERA DRIVE (TIMING) BELTS
I've got lots of them for the CD17. Take a look at this post.
I'd guess they're the same for the CD20, but I am not certain.
The CD17 has two timing belts: one drives from the crankshaft to the cam, has two tensioners and drives the water pump too. This belt fits that side of the engine. I think that that belt is 13028-54A85, $32, but there is some confusion. See the pic:
The other belt goes from the other end of the camshaft to the IP. I don't have this belt:
cam shaft drive belt and a injector pump drive belt.
cam belt is not the same as cd17. most are semi round.
I had a few different part numbers ,just different brands sold by different Japanese dealers, several dealer networks selling different vehicles.
my early cd20 had a cd17 injector pump belt-square teeth. later models have the vac pump and electronic controlled IP on the rear so they have a different belt.
there are several part numbers for the belts.
