Air inlet cowling
Air inlet cowling
One thing these little diesels do very well is SHAKE loose metal and plastic parts ... bad as a Harley. :wink:
There have been 1 ... then 2 ... and now 3 vibration rattles emanating from the cowling between the hood and windshield. Pick an RPM between low/cold idle and 1500 or so .... barzzz .... bizzzzzt .......vrrrrrrt.
Removed cowling, found two push clips missing and two tab holders vibration chaffed. A little bending, felt, and all new plastic thingies ... no more musical sheet metal.
The four push-pin clips are just that .... not phillips screws.
Been thanked: 8 times
You don't happen to have a pic of these little buggers, do you?
I bought one extra "tab holder". Because it's black, it does not photograph / render well at all.
The push-pin clip is a one-use affair. Just pry up under the cowling and break it. Pep Boys has these ... common interior fastener.
Tab holders in stock at a Nissan dealer. $1.62 ea
Push-pin clip in stock too. $1.27 ea
Users browsing this forum: Google [Bot] and 24 guests
