Oil leaking everywhere
cseger1
Thanks for anyone with the patience to even read my threads anymore. I think the fix for this truck is 5lbs. of TNT. And yet I push on.
So here's today's quandary:
There is a lot of oil leaking out of this truck. 1qt. per 200 Mi. I feel like a rolling superfund site. I park on a tarp and am actually dripping enough to recycle it. The main culprit is the recently famous oil pump line which I'll be sending to a hose shop as recommended. yesterday I replaced the valve cover seal and stopped that leak but there is still a lot of oil coming from the upper rear portion of the engine. Is the vapor seperator a good plcae for a leak to pop up? Is there an O ring or something to replace on it?
Christian
1981 720 SD22
1981 720 SD22
- Has thanked: 5 times
Off the top of my head, and excluding the VC gasket, possible oil leak points include:
- Camshaft and oil galley rear plugs (under flywheel), not very likely but possible
- Oil pressure switch (behind and below oil cooler, right side)
- Oil cooler o-rings
Around here, the car washes work well enough that I don't take cleaner with me. I own a pressure washer, but I like to leave the crap at someone else's place
After I've removed the big stuff at the car wash, I do the detailed cleaning at home. Well, at work.
BTW, don't use the "Engine Degreaser" option at the car wash, it's usually a waste of money. If you don't get hot, susdy water at high pressure from the "Soap" function, find another car wash. There are plenty of bad ones. Sometimes you have to hunt for a good one.
- TooManyIdeas
pbknowles
The vapor separator has a square section rubber o-ring that seals it to the block, could leak there, but on mine the seam where the separator was assembled leaked too. It is built like a tin soup can. It has a rolled and crimped joint where the body proper is joined to the back plate, and this joint originally had some kind of sealer in it. On mine the sealer was dried out and it was drooling from this seam. I just cleaned it up real good and smeared a layer of silicone around the outside, no more leak.
SD22 powered '85 Chevy S-10
Nope, that'll take off paint, and will also corrode any aluminum parts. Stay away from oven cleaner, it's too hard on paint, plating, and aluminum.TooManyIdeas wrote:EZ-OFF Oven Cleaner
ffdjm
Be careful of pressure washing engines. It's all too easy to splash water into electrical parts, where it causes corrosion and failure. For removing of oil I use white gas (Coleman fuel) in a garden sprayer. Kerosene works as well but takes a while to evaporate. Don't use pump gas. The stuff is full of benzene which is a carcinogen. This won't remove other forms of dirt. For that scrubbing with a brush and degreaser mixed with solvent followed by water rinse is most effective.
Douglas
Douglas
This really annoys me.ffdjm wrote:Be careful of pressure washing engines. It's all too easy to splash water into electrical parts, where it causes corrosion and failure. For removing of oil I use white gas (Coleman fuel) in a garden sprayer. Kerosene works as well but takes a while to evaporate. Don't use pump gas. The stuff is full of benzene which is a carcinogen. This won't remove other forms of dirt. For that scrubbing with a brush and degreaser mixed with solvent followed by water rinse is most effective.
Douglas
NO VOLITILE organic cleaners where electrical sparks or strong magnetic fields are generated. And you certainly don't need kerosene or ANY "fuel" laying on an engine... even a diesel. Worried about water corrosion? How about your solvents getting into alternator, starter, IPC motor bearings?
You worry about carcinogens ... how about where all that dirty "fuel" you washed off headed to? COMMUNITY ground water.
There are aerosol engine cleaners. At industry levels, VOC solvents have been replaced by citrus and other low polluting formulations. Yeah they don't work as fast but ... I like cleaner water.
Rant over.
I use high pressure water everywhere. It's seldom a problem with electrical parts. In particular, you can soak alternators. As long as you don't store the vehicle in a wet climate, the water is by-and-large going to evaporate.
Up here in the Great Pacific NorthWet, we know corrosion. I'm not washing my engines every week, I work hard to get 'em clean once, then I can rinse them off every few months to keep 'em that way.
Crud I wash off is crud that won't attach itself to me when I have to work on it, and oil + rubber parts = short life.
I hate oil leaks and dead cylinders. Oil burning doesn't bother me as much.
OTOH, oil all over a diesel is pretty much only a fire hazard. On a gasser, it's a much bigger deal, with all the sensors, hoses, and high voltage trying to get out.
