how much atf fluid?
nogrip
how much atf fluid?
Post by nogrip »
ive got a 3 speed with od trans..
im swapping the engines over and the fluid has gone all over the show because i had to lift it all out on a mad angle..
so...
how much atf fluid do i need to put into the torque convertor?
and how much in the trans? cant remember what model it is but the numbers n347b ring a bell???
ld28t in a 81 transit van
Re: how much atf fluid?
nogrip wrote:ive got a 3 speed with od trans..
You don't have to put any ATF in the torque converter; it will fill fine by itself.
I can't recall how much ATF is needed in the L4N71b. Have 8 quarts on hand; if the converter has been drained, you'll probably need about 5-6, is my guess.
nogrip
Post by nogrip »
L4N71b <<< haha yep thats it, i was way off..lol
so it is self filling?
how much is a quart?? we use litres here :wink: :lol:
dn29626
Post by dn29626 »
1 quart = .945 liter
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
nogrip
Post by nogrip »
thanks...
also does anyone know off hand what the torque setting is for flywheel/flex plate bolts?
hope this new motor is a good one and not a lemon...
nogrip wrote:so it is self filling?
Yes, the ATF pump, which is driven by the "outside"/shell of the torque converter, will fill the converter.
Sorry, I didn't read where you are. I'll do better next time ;)
The 1981 FSM, page AT-62, says:
Drive plate to torque converter
39-49 N-m
4.0-5.0 kg-m
29-36 ft-lb
The 1984 FSM says the same.
I can't find my 1982 & 1983 FSMs right now.
nogrip
Post by nogrip »
haha all good...cheers for the torques...
the replacement engine has a few differences to the one that came out..
old one:
oil cooler unit on the filter housing
front sump
different looking IP only slightly though..
new one:
no oil cooler on the filter, and it sticks straight out rather than on an angle
mid sump
and one was manual and one was auto..the end of the crank is different too..
so the torque convertor has no bush to sit into...it should be ok as its fixed onto the flex plate....
all the turbo bits are being put on to the new motor too :wink:
