ive got a 3 speed with od trans..
im swapping the engines over and the fluid has gone all over the show because i had to lift it all out on a mad angle..
so...
how much atf fluid do i need to put into the torque convertor?
and how much in the trans? cant remember what model it is but the numbers n347b ring a bell???
how much atf fluid?
Re: how much atf fluid?
You don't have to put any ATF in the torque converter; it will fill fine by itself.nogrip wrote:ive got a 3 speed with od trans..
I can't recall how much ATF is needed in the L4N71b. Have 8 quarts on hand; if the converter has been drained, you'll probably need about 5-6, is my guess.
Yes, the ATF pump, which is driven by the "outside"/shell of the torque converter, will fill the converter.nogrip wrote:so it is self filling?
Sorry, I didn't read where you are. I'll do better next timehow much is a quart?? we use litres here
The 1981 FSM, page AT-62, says:also does anyone know off hand what the torque setting is for flywheel/flex plate bolts?
Drive plate to torque converter
39-49 N-m
4.0-5.0 kg-m
29-36 ft-lb
The 1984 FSM says the same.
I can't find my 1982 & 1983 FSMs right now.
haha all good...cheers for the torques...
the replacement engine has a few differences to the one that came out..
old one:
oil cooler unit on the filter housing
front sump
different looking IP only slightly though..
new one:
no oil cooler on the filter, and it sticks straight out rather than on an angle
mid sump
and one was manual and one was auto..the end of the crank is different too..
so the torque convertor has no bush to sit into...it should be ok as its fixed onto the flex plate....
all the turbo bits are being put on to the new motor too
old one:
front sump
new one:
mid sump
ld28t in a 81 transit van
