The negative battery terminal was cracked, and I'm trying out a different method to repair it. NAPA No. NW728079, $10.88 (2012).
Hi, Paul:plenzen wrote:This might work for me and the + term on my Nissan.
Does it come in different sizes ?
Part No. Description Qty Price Al's notes BMK23-EA Dual Remote Mounting Kit 1 208.50 The base universal mount kit with hoses, fittings etc. The base mount without the rest of the kit is BK309 BK295-EA Spin On Adapter 1 44.95 Adapter in place of the stock oil filter. This one is 3/4"-16 UNF for my Ford 4.0l OHV. A common size. G1570-EA Oil Sample Valve 1 22.35 This is the "deluxe", button-operated valve, with the screw-on discharge cover. BP209-EA Adapter Fitting, 3/4"-16 to 1/4" NPT 1 4.00 The adapter for the sample valve above. EABP90-EA Absolute Efficiency By-Pass 1 29.30 The smallest/shortest bypass filter. One quart capacity. EAO15-EA Absolute Efficiency Oil Filter 1 14.25 A standard full-flow filter, by AMSOil. IDK if it's worth the price, but I'm going to try it. KIT06-EA OAI Non-Postage Paid Kit 1 17.95 An oil sampling kit for lab testing of used oil.That list came to around $380 shipped and taxed. It's not particularly simple to figure out what to order; I'll have to see if I did it correctly.
