Engine Vibration ... mounts sacked?
Al. I'm considering 'changing' the engine mounts. Seems like the engine vibration has gotten a little too much.
I find several variations on SD22 replaced mounts (aftermark). The type on my truck seem to have compressed (sacked) to the point the surround C bracket's could be the reason for vibration. (very similar to #WSEM-8144). I have checked for separate of the rubber blocks by lifting the engine ... mount is still good. I should add that the drag link passes the engine pan REAL close.
Different aftermarket engine mounts
Compare the cushion thickness mount. (WSEM-8145 left & WSEM-8146 right). NAPA shows this model too.
WaddaYaThink?
WaddaYaThink?
- Been thanked: 8 times
Wow, that's a whole lot of choices.
Looking them all over, I guess I have to say: I have no opinion.
- Knucklehead
Be careful, I can't remember which one, but one of the two that I got that was listed didn't fit, and the next one had the locator pin slightly off. I filed it down a little and it works. Don't trust parts books!
Don't know how you can be sure to get the right one, other than trial and error, but be prepared. You might not want to do the mail order thing.
'29 HD FD export model
I had a funny feeling about that ... after finding several sources. And lucky for me .... I found YOUR two replacement mounts.Knucklehead wrote:Be careful, I can't remember which one, but one of the two that I got that was listed didn't fit, and the next one had the locator pin slightly off. I filed it down a little and it works. Don't trust parts books!Don't know how you can be sure to get the right one, other than trial and error, but be prepared. You might not want to do the mail order thing.
Your mounts are the same as NAPA sells. But the mounts in my truck is this: (.... with the shield curved away from the mount.
- Knucklehead
Well, I may not have had those mounts in the correct layout when I took the picture. I was mostly trying to account for all the nuts and bolts. Mine used to look just like yours, but the ones I got from Autozone had those little thingies sticking up. My shield (which I believe is to keep spilled fuel off the rubber) goes the same way yours does. Still, the point is it might be best for you to have them in hand at a parts counter for a satisfactory if not exact match.
Would you like a measurement before you take yours out?
SureKnucklehead wrote:SNIP- Mine used to look just like yours, but the ones I got from Autozone had those little thingies sticking up. -SNIP-
One other question. Now that you have the "new" mounts, how close does the engine oil pan come to the steering drag link?
Both mounts replaced for the SD22 seems to have been updated to the SD25 right mount. (but with some variations).olpeppy wrote:i've looked online at several places for my 84 sd25, but all i can locate is the left hand side only. Are they different than the 82 sd22? just wondering for future replacement. thanks
But as you see in the schematic, the LEFT mount on the SD25 is unique.
- Knucklehead
The mount thickness incl. metal is about 2.125". The pan is about .75" above the link. I can just barely hook my middle finger around it and slide it past the pan, which says as much about the thickness of my fingers as anything else. Can't give you any measurements on the locator pins if that's why the orange arrows are there. By little thingies I meant the upward extensions of rubber and metal on the mount, which I can only guess is to keep the motor from falling out should the rubber fail.
I've got too much time to do this.Knucklehead wrote:The mount thickness incl. metal is about 2.125".
These have 2-1/8" height too. What I see is the effect of heavy weight getting pass to the frame.
Left side
See replacement mounts installed
Right side
HAH! That paper post-it pad is 1/4" thick.Knucklehead wrote:The pan is about .75" above the link. I can just barely hook my middle finger around it and slide it past the pan, -SNIP-.
- Knucklehead
Everyone around here ... wants $57-65 each. From "carjunky"Knucklehead wrote:That oil pan looks like it needs a good flossing.
mail, I can get BOTH parts for ... (includes FedEx for free when item is over $50)
Core Charge: 0.00
Sub Total: 59.46
Shipping: 0.00
Handling: $0.00
Tax Total: 4.31
Order Total: 63.77
I ordered ... let's see what happens.
Followup: Both engine mounts arrived this morning (Aug 22). The parts are as requested. They are different from the OEM which I expected. From Thailand. Now ... some time.
http://www.carjunky.com/
- TruckA
I don't know if it matter much for what you're doing since you already received the replacements. But, for the SD22 swap I'm in the middle of, the stock mounts were in sub-par shape so I taped off the bottom and one of the sides of the mount and squirted urethane into the voids. This should firm things up a little more and hopefully save me some coin, I got the tip from some DSM guys that use this stuff to firm up their mounts when they start to build big turbo power. It is called Windo-Weld and is used to adhere windshields, it was $15 for the tube.
David
David
- Knucklehead
