eBay (IN): SD2x DD starter, reman $65 shipped
Locked
Auction 200153000211, ends Sep-22-07 08:29:33 PDT
Condition: Remanufactured
Up for sale is a Remanufactured Nissan Starter Lester # 16771 that fits the following applications:
NISSAN Car & Lt Trk 720 PICKUP 2.2L (Diesel) 1981-1983
NISSAN IND Ag & Industrial LIFT TRUCKS F01 SD22 Diesel Engine
LIFT TRUCKS F02 SD25 Diesel Engine
LIFT TRUCKS H01 SD25 Diesel Engine
LIFT TRUCKS H02 SD25 Diesel Engine
LIFT TRUCKS QF02 SD22 Diesel Engine
LIFT TRUCKS QF02 SD23 Diesel Engine
LIFT TRUCKS Various Models S23 Diesel Engine
LIFT TRUCKS Various Models SD22 Diesel Engine
LIFT TRUCKS Various Models SD25 Diesel Engine
YANMAR Ag & Industrial ENGINES Various Models 3T95L
Good price for a reman starter for the SD.
Nobody bought it, so I did, from the relist.
I just sent mine out to get rebuilt as it was having a few issues. I will take photos of it when I get it back. Mine is a reduction type and I have looked at some of the other pictures that are posted of them and it seems different even from those. ( I will look closer at it when I get it back though)
My question is:
Will any Nissan SD2X series starter with the 9 tooth pinion work in the SD 25. Can I use the DD one?
The re-man one that Auto Parts Plus located for me was $400.00+ The rebuild is just under $200.00. I would like to have a spare just cuz.
Next time trans comes out I will do the ring gear as well. If not a new one will turn this one 90 degs.
Another question is: Are the ring gears available or are they different from application to application. ie: Heavier flywheel in fork lifts etc?
I thought I'd replied to this, but I don't see it . . .
plenzen wrote:I just sent mine out to get rebuilt as it was having a few issues. I will take photos of it when I get it back. Mine is a reduction type and I have looked at some of the other pictures that are posted of them and it seems different even from those. ( I will look closer at it when I get it back though)
I would appreciate those pictures.
I don't know. I suspect it will, but I don't know that.
I just checked NAPA, and they list the same starter choices for 1982 SD22 & 1985 SD25. I think that they're interchangeable.
Raylock Premium rebuild, GR style, 446001, $197
Beck-Arnley rebuild, DD style, 1870354, $170
AFAIK, the GR & DD starters are physically interchangeable. I've seen both styles on SD22s.
I seem to find wear at four places on Fours, though almost always worse at one spot. Will turning the flywheel 90° help?
For the '86 720 SD25, Nissan lists a part No. for the ring gear, separate from the flywheel:
Ring gear = 12312-37501, $112
Flywheel = 12310-P0704, $280
NAPA lists the flywheel, but not the ring gear separately (using application 1986 720 SD25, of course, since your D21 SD25 truck doesn't really exist!). NAPA SDF 304, $58, but that number doesn't come up on the retail NAPA site, only on their ProLink (dealer) site.
I will have to see if there is a dowel in the flywheel or if the bolt pattern is Assym. I think that maybe I should look at picking up a starter next time I am across the 49th. I go to Montana on a pretty reg basis and I will check with NAPA there. Like I said they want 400+ for one from Auto Parts Plus. The Ca $ and US $ are virtually the same right now so don’t know why the huge price discrepancy. The one that you bought also crossed to Yanmar Ind/Ag motors and since my dad still works building gen sets for LSP in Vancouver I sent him the number to cross and see what the Yanmar is.
Just a thought and wonder if you would know if the RPM on the DD is different from the GR? I wonder if cranking speed will play a factor in the 22 as opposed to the 25. Perhaps if the DD one is a bit faster perhaps that will also assist in the cold starting? Just a thought, and if anyone had a sample of both to test, if he hasn’t already done it,,, you will. Or you will have access to the RPM in the specs someplace.
Thanks
Near as I can tell from the Manual I have a choice of three GR starters.
S114-453, or 454 or S13-92A. Both equipped with the pinion clutch mechanism and that is what I suspect is pooched on mine. I thought at first it was grinding against the ring gear but it does not appear to be. I have rolled the engine 360 and found two wear points, and used a die grinder with a small burr on the end of it to smooth out the sharp messed up pieces on the back side of the chamfer lead in. I will still think about turning the ring gear or flywheel (if I can) 90 degs next time. There are three other models of starters in the FSM that are DD's and appear to have the right nose piece bolt pattern on them as well. The pinion however looks too long, and are most likely for gassers.
There is no where in the rebuild section fo the FSM that states RPM that I can find either.
Interesting little guys for sure!!
The eBay starter arrived, and pictures are in this post.
Locked
Users browsing this forum: Bing [Bot] and 4 guests
