Battery Q: how much do I need?
Hello, Alan:
SoCalanz wrote:> Hello. I am new to the site. I just bought a 1983 Maxima Wagon
> complete, less the battery. People have told me I need at least 850
> amps but I do not know if that it cranking amps or cca. On the
> batteries I have seen the CCA is always lower than the CA. Can you
> give me some help with this? I live in Southern California and it
> rarely gets too cold. In fact it is Nov 6th and it should be around
> 80 today.
Congratulations on your acquisition. The 1983 Maxima diesel Wagon is the most-desirable of all the Gen1 Maximas, IMO. It has the coil-spring rear axle which is worlds better than the leaf springs we got in '81 & '82, and the diesel-only overdrive automatic transmission, a one-year-only trans.
Regarding your battery: this engine really works best with a lot of battery capacity. Many similar-sized diesels of that era required TWO batteries in parallel to get adequate performance.
You can get away with a 750 CCA battery for a couple of years, but if you plan on keeping it, you are better off in the long run to buy the biggest, baddest battery you can. I use and recommend Interstate batteries, and my last two cost $104 ea. Do not, under any circumstances, buy an Exide battery, no matter how much cheaper it is: you WILL be sorry.
The GP system draws 50-150 amps during startup, and add to that the starter draw, and you need a lot of battery.
I hope this helps.
In future, it's best if you ask Qs of this sort in a post on the
forum, rather that privately. That way, all can learn. In fact, have
you tried Search on the site about batteries? This Q has likely been
asked and answered before!
SoCalanz
Post by SoCalanz »
Thanks for the help. The biggest, baddest, single battery I found was an AC/Delco with 850cca and 1000ca. Also, thanks for the Exide warning. I was going to get that one before I found this one.
1983 Maxima Diesel Wagon
1992 Suburu SVX, Lsi, AWD
1995 Suburu SVX L, AWD
I'm running Interstate's top-of-the-line MegaTron Plus MTP-27, @750CCA, 85 month. Be aware that Interstate's ratings are conservative. I used to sell them and their warranty failure rate is a fraction of the other brands I've sold/seen.
A member with a lot of experience posted that he likes the Interstate Group 31 battery. That whole thread is good reading on batteries and the Maxima diesel, BTW.
dieseldorf
Unknown brand
Post by dieseldorf »
A view years ago I bought a battery for my Volvo Diesel Wagon. At that time, I lived in Crescent City and there was not much choice of suppliers. But then I saw a battery rated at 1000CA at a "Coast to Coast" hardware store. As I remember, the name on it was "Magnum" or something like that. The battery was small but amazingly powerful. That was the best battery I ever had. I sold the car with the battery and soon regret not to kept it. The hardware store chain does not exist anymore and I do not know what brand it was or who made them.
I compare Cold Cranking Amps (tested at 0° F), not Cranking Amps (tested at 32°F). From Interstate's site:
Cranking Amps (CA) - A rating that is used to define the battery's ability to start an engine in moderate temperature conditions. BCI (Battery Council International) defines it as "the discharge load in amps that a new, fully-charged battery at 32ºF (0ºC) can continuously deliver for 30 seconds while maintaining a terminal voltage equal to or higher than 1.20 volts per cell." This artificially high rating should not be confused with CCA, which is conducted at 0ºF (-17.8ºC)
Cold Cranking Amps (CCA) Cold-Cranking Amps (CCA) - A rating that is used to define the battery's ability to start an engine under low-temperature conditions. BCI defines it as "the number of amps a lead-acid battery at 0ºF (-17.8ºC) can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12-volt lead-acid battery).
The Sears Die-Hard line of batteries was, for many years, a very good battery. I believe Sears has switched suppliers and this good reputation may be at risk.
I stick with Interstate. But I've had a pair of matched Delcos in diesel service last almost eight years. That was a while ago though.
