BTW Al, that isn't a Toyota 2LT your working on is it? I'm confused by the turbo IP vs. the photo that I think shows a non-turbo intake on the Toyota engine.
Bosch Diesel Injection Pump Timing Indicator Tools
Dial Indicator and Holder
(Please note : Picture is for reference only).
This set has a dial guage with an 8mm shank.
(rare at this price) Tools are used for the accurate setting of the Bosch diesel fuel injection pump timing. The Holder screws into the back of the injection pump, giving a dial indicator reading necessary for setting the correct pump timing. This set comes complete with the correct tools for the job! Contents: Metric Dial Indicator, plus holder plus extension pins (2) making the timing easy to set, as the timing has a range from 0.83mm to 1.15mm. For use on VW and Audi diesels. Indicator Holder Set - Suitable for timing Bosch VE injection pumps. Includes M8, M10, and M12 adapters. To be used in conjunction with Dial gauge. Applicable: Bosch VE fuel pump, Diesel pumps. Indicator Holder for both size shanks Also works with 1981-1986 Volvo 6 cyl 2.4L diesels, 1989-1994 Dodge 6 cyl 5.9L diesels.
The steel distributor head mates to the alum IP body with four long screws, one in each corner.goglio704 wrote:I see the three screws retaining the CSD bracket, if one of them also secures the head, it must not be a square pattern that retains the head?
Can't: If the line nut does not loosen from the delivery valve holder, the steel injector line must twist and be destroyed in order for the delivery valve holder to back out of the distributor head.What would happen if you let the delivery valve holder back out with the line . . .
Al,What would happen if you let the delivery valve holder back out with the line . . .
