turbo or not turbo
sd25hardbody
turbo or not turbo
Post by sd25hardbody »
:? I'm always looking the differance betwen industrial and common sd25 but I's not the subjet....my question is, Is the td25 the same engine as a sd25+turbo??? if not what is the difference, and can I put a turbo on my sd25???
weezle_deezle
turbo good...
Post by weezle_deezle »
Turbo it!! Same answer I've given multiple times- more torque, better MPG, and the cool whistley sound...
I'd rather bathe in diesel than get a drop of gasoline on me. Makes a nice cologne too.
sd25hardbody
ok, but do I have modification to do?? injector...pump...?? or I put the turbo and ....finish.
dn29626
Post by dn29626 »
I know this thread has some age on it.
What source is a td25 turbo available from? I would like to install one on my 82 SD22.
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
The TD engines are completely different than the SDs.
dn29626
Post by dn29626 »
Are you saying it will not work?
Anderson , SC
Since Fall 2009
Who can say? Someone who knows both engines. That's not me, because I've never seen a TD25 in the flesh, as they were never sold in the US.
Just a guess, though: modern automotive diesels have better airflow (volumetric efficiency) than the old SD. I don't think that a turbo from a stock TD25 application would be a good size match for the SD, even if you have an SD of the same displacement (ie an SD25). Most of the SDs still running in the US are the 2.2l, not the 2.5l.
IOW, there has got to be better turbo choices around than a turbo from an engine that was never available in the US in any significant numbers.
Glegor
Post by Glegor »
K14 off a VW diesel, or some sort of similarly sized diesel will work pretty well..
