And some others...
Click image for larger view.
Acquire a better breaker bar.Zoltan wrote:Tried with a foot long braker bar + pipe, but stopped because it was obvious that I am going to destroy the braker bar before the plug would move an iota.
Not a tube, but another, similar plug on the driver's side, about halfway up the case. It has an external square part that you can put an appropriate wrench on. You can see it in this pic (click image for larger):2. HOW DO YOU REFILL THE TRANS? I don't see any refill tube for the transmission.
I'm cheapasavage wrote:SNIP- If you're really, really cheap, and don't mind a mess, you can use a long piece of hose, one end in the filler hole, and run the hose up to the engine compartment, other end of hose on the pointy gear oil bottle adapter, or small funnel. You will have a puddle when you're done, but the trans will get filled.
I have shop connections so for a walk-in stranger, $1000-1200 for the whole job including a new clutch would be what I'd expect. Of course, there are Hawaii prices(?)Zoltan wrote:Gentlemen, SNIP
I'd be interested in what part were replaced in Philips trans and how much it cost him. My truck makes almost identical noises to his description.
I didn't buy any parts from an online supplier, though I may have referenced drivetrain.com .Zoltan wrote:Al, the kit you purchased from the online store looks it has Japanese bearings, are they OEM? The full set of BCA bearings come out around $145 from partsamerica.com . . .
This was not all of the brgs in the transmission, there are two that I didn't replace because I did not want to disassemble the cluster that far. The two brgs I didn't change are the centre support brgs, very std ones (6305, 6306) that are not expensive, except for the special puller/presswork to get to them. They are not the "ones that go bad". A comprehensive rebuild would replace them, of course, but I didn't replace the synchronizers either -- I was using a donor gasser gearset that was in quite good condition.BCA 205 $26.64
BCA 306-LO $71.02
BCA 204 13.40
NTN 63/22 $90
Extension housing bushing $16
If you have noise, the front bearing(s) is bad. You've seen the pics Philip & I have taken of ours, upthread.claybodie wrote:There sound in the transmission is, like mentioned above, louder in lower gears - but several people tell me it sounds ok, like the sound of an old transmission accepting load when you let off the gas. It sounds like grinding to me though - or maybe not in first and second gear.grinding, but definately FRICTION.
My question is, should I get this checked out now or just keep driving and not worry about it til things much worse?
I've no idea on this one. Are you sure it was oil and not rusty water?The other question is: when I was changing my center bearing I very stupidly jacked the front of the truck up a little bit and a red liquid came out of the tube where the propeller shaft goes into the transmission. What the hell is that? At first I thought someone might have put automatic trans oil in the transmission, but the trans oil I drained is dirty gear oil and not red.
No.Is there another cavity in there ?
