Injector thread size/pitch
pbknowles
Hello, new to the group......I have a few questions to ask but I am going to start off with (hopefully) an easy one. I am trying to verify the thread size and pitch of the SD22 injectors. There is a guy on eBay selling compression test adapters and he has one for "Datsun" that is 24mmx2. I am hoping that it would fit my SD22.
Thanks!
Phil Knowles
Thanks!
Phil Knowles
SD22 powered '85 Chevy S-10
Re: Injector thread size/pitch
Welcome.
Al assembled a Compression Adaptor set using the glow plug hole.
Do replace the tip sealing washer before you reinstall the injectors.
So, is this the one that was on eBay recently? How 'bout some pics or background or something . . . post a story, over in the User Rigs forum.pbknowles wrote:SD22 powered '85 Chevy S-10
Phil, I bought one of the same injector adapters from El Paso Tools on eBay, 24mm, and the (integrated) nipple on the end is some bastard size that doesn't fit my Snap-On and Parker-Hannafin hydraulic quick-connect fittings on my compression gauge. Also, it appears to me that the check valve (Schraeder-styel) is NFG on mine.
How is it working for you?
pbknowles
eBay adapter
Haven't tried mine yet as engine is all apart. The seller warned me about the wierd adapter before I purchased. I just chucked it in my lathe and faced it off, followed by cutting a 1/8 F NPT and installation of a standard Q.D. fitting. The other day I was eyeballing a diesel compression test set at harbor freight and it appears to have a non-standard q.d. as well. Just something to remember....
PK
PK
It looks like I may have to lathe the fitting smaller -- there's plenty of material there to do it. I'm negotiating for someone here with the facilities to mod it for me.
Users browsing this forum: Semrush [Bot] and 18 guests
