If it runs OK after a minute or so, that's usually GP or GP system related, not injectors. A lot has been written about that here.EvergreenSD wrote: This concern is being forced onto the back burner by another problem. The cooler weather here has resurrected my cold-starting woes with a pronounced miss and a bunch of smoke.
* Cold Weather Starting Difficulty *
EvergreenSD
I have already replaced the Glow plugs and checked the voltage supplied. I really think that they are working since the engine always lights right off when they are warm, it just misses while it tries to warm up. This definitely lasts longer than a minute if it is cold out. My theory is that it is an injector that no longer sprays a decent pattern when the fuel is cold. I think I 'm going to pull the injectors to see what they look like. I've definitely been wrong before . . .
Are the glows staying energized long enough? On a 45° morning,EvergreenSD wrote:I have already replaced the Glow plugs and checked the voltage supplied. I really think that they are working since the engine always lights right off when they are warm . . .
The dash Glow light goes out when -minimum- glow time has been met. This is an estimate based on coolant temperature. The Type I system glow plugs take about 15-20 seconds minimum glow time regardless of engine temperature. It's just that with a warm engine, the glow plug is not the only source of heat in the combustion chamber. The glows stay ON until you hear the duty solenoid "thunk" OFF some 10-30 seconds later depending on coolant temperature.
Twenty seconds is a long time, when you're sitting in a cold cab and want to be somewhere else.
EvergreenSD
I don't think that I explained myself very well in the last post. Given the way it is tempermental in cooler temps, I wait for the GP to cycle off on a cold start, then turn the key off and back on to start. You're right it does seem like a long time but I have definitely been waiting for longer than 20 seconds, more like a minute. Also, what I meant to say is that after the plugs are warmed the engine starts immediately on the first couple of cranks, then it settles into a rough idle with a pronounced miss. Also, the miss persists after the plugs cycle off sometimes.
moose60
I have very similar symptoms. When I have the time, I plan to inspect the afterglow system. My understanding is that it glows after startup for a period of time (30 sec? a minute?) to reduce smoke and smooth out cold starts. When the engine is COLD, I hear the afterglow relay click off one or two seconds after startup. When the engine is warm, and I let it idle slowly, I will not hear the relay 'clunk' for 15 to 30 seconds. I have cleaned the thermo switch that threads in to the thermostat housing, but with no change.
Good luck with yours Evergreen.
Byron
82 Datsun 720 KC SD22
MPG Machine
MPG Machine
That's air in the pressure lines or a bad injector, yup. Since injector overhaul is a scheduled maintenance kind of thing anyway, I agree that having them tested etc. is a good next step.EvergreenSD wrote:what I meant to say is that after the plugs are warmed the engine starts immediately on the first couple of cranks, then it settles into a rough idle with a pronounced miss.
EvergreenSD
Fortunately, my afterglow system seems to be consistent and functional as well, I would guess it clicks off after about 15-20 after starting. I would be happy to be talked out of an injector rebuild I can't really afford but I kind of feel like I've been through everything else: new GP's, adjusted valve lash, new filters and fuel lines etc . . .
Does nobody like me theory that one or more injectors is spraying a mariginal pattern that doesn't burn adequately until the engine warms up? Also remember that I'm not getting the most phenomenal mileage either (about 32 on the last long trip).
zen
ok..
i have had cured this problem on my sd33..(inlne kiki bosh mz rbd pump)i will give details of what i did,and hopefuly it will be of some use to you..??
IF THIS IS COLD WEATHER related only and not all the time then...
its unlikey to be air in fuel..would do it all the time..
check if not replace glow plugs..just take them out and wire them across a battery and see what happens..beware they reach nearly 1000 degrees C in 15 seconds ... a bright orange/yellow glow so dont touch then! Dooh
check injectors..at a pump shop..(unlikley but well worth doing anyway,get them serviced at same time)
but formost check ip timing..mine was as simple as needing a slight tweek on pump ADVANCE it a degree or two..mine acording to lines on pump was correct,but on advancing almost completly removed start up smoke(none at all on first start up above 0c (32f)1-5 secs below it(and hardly visable)
miss fire removed...
hope this helps..do ip first cos it costs nothing..
oh could be low compression,but we dont want to go there
turbo it
zen wrote:check if not replace glow plugs..just take them out and wire them across a battery and see what happens..beware they get f***ing hot, infact the glow.so dont touch them..dooh
EvergreenSD wrote:I have already replaced the Glow plugs . . .
A little earlier in this thread, Al provided a scan from the FSM showing how temperature affects the AutoAfter Glow timer.
NOTICE the word "minimum" is used twice in that image. BUT ... what is not mentioned is that when the dash light goes out, the glow plugs are still ON until ... the duty relay under the hood goes "CLUNK."
I did not find a distinction between California vs. "Non-CA" AutoAfterGlow timers (surely that could be an undocumented CA concession for smog) but mine (CA model) does not discontinue operation above 140 degrees F as is shown on the chart. With a hot engine, the dash light goes out after 5 seconds but the glow plug duty relay stays ON for 30 seconds if you care to wait it out before starting.
AND, the glow plugs are run for an additional 30 seconds after the engine is running regardless of engine temperature.
Glow Plug Experience
Combustion Cackle with Cold Engine
zen
asavage wrote:zen wrote:check if not replace glow plugs..just take them out and wire them across a battery and see what happens..beware they get f***ing hot, infact the glow.so dont touch them..doohEvergreenSD wrote:I have already replaced the Glow plugs . . .
and you have SEEN them working?? cos i have replaced glow plugs before,to still have probs..reason faulty new glow plug...
so it dont hurt(unless your me) to check em..does it??
turbo it
IF by chance glow plugs for the Type II AutoAfter Glow system are used in the Type I AutoAfter Glow system, the Type I system will keep them ON at full system voltage much longer than the Type II glows are designed for so .... early failures.zen wrote: And you have SEEN them working?? cos i have replaced glow plugs before,to still have probs..reason faulty new glow plug...
- Knucklehead
Please let it be clear for posterity and the uninitiated that when we say "see", we mean see the spray pattern. Wasted injectors can still pass visual inspection. These things defy eyeball engineering. A bench test should cost nothing, takes less than a minute per injector, and you get to watch!I think I 'm going to pull the injectors to see what they look like.
'29 HD FD export model
EvergreenSD
But if they look bad they are bad, right? I spoke with a person at the diesel injection shop and asked about testing and he told me to just check the nozzles for signs of wear. Maybe he just didn't want to volunteer to bench test?
Is there anything I need to know before pulling an injector or two? We are down to one car now so having the injectors done will mean downtime. Will I be able to reuse the sealing washers for a short time if I pull them to have a look and then need to drive somewhere?
There is no short cut here. The "wear" or "damage" is NOT visible until you completely disassemble the injector and ... remove the pintle valve from the nozzle and examine the pintle under high magnification.EvergreenSD wrote:But if they look bad they are bad, right? I spoke with a person at the diesel injection shop and asked about testing and he told me to just check the nozzles for signs of wear. Maybe he just didn't want to volunteer to bench test?
Fuel Injectors
The above link has all that information. Your rebuilder needs to supply those nozzel tip sealing washers. Use ONLY the tip washer ... the ones you dug out of the head. Yes, digging the original flat copper washers out of the head is a pain. The FSM requires replacement everytime injectors are removed. You could ask for the SD25 style crush washers. Again, refer to the above link.EvergreenSD wrote:Is there anything I need to know before pulling an injector or two? We are down to one car now so having the injectors done will mean downtime. Will I be able to reuse the sealing washers for a short time if I pull them to have a look and then need to drive somewhere?
Users browsing this forum: Google [Bot] and 22 guests
