SnapOn MT257A on E-Bay
SnapOn MT257A from a new seller with zero feedback. Probably go cheap, it will have to for me to bid with no feedback.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... RK:MEWA:IT
- Has thanked: 5 times
Yeah, after only one MT257A has come up on eBay in the last year, two sold in the last two weeks. Both sold for over $200. I bid on them both, but I'm not paying anywhere near that much, not when I can use one of my two J-33300s instead.
I'll bid on this one too, but it'll likely go for those same inflated prices.
" This listing (#4603739463) has been removed or is no longer available. Please make sure you entered the right item number. "
I wonder what happened. I was planning on bidding on it, but it's gone. Did one of you buy it?
I didn't buy it. It didn't have a buy it now and I don't think it got a bid. It was a brand new seller. I think E-Bay pulled the listing. I've never seen an item completely disappear like that.
Oh, I have, several times. For example . . .goglio704 wrote:I've never seen an item completely disappear like that.
I bid on something a couple of weeks ago, and eBay cancelled the auction. They sent me an email saying they did it, and that because I was a bidder they were notifying me, but eBay never said specifically why the auction was ended, only that some terms of use were violated [shrug].
Anyway, I'm still looking. I'm not going to pay $200 for one, no way. My local Snap-On dealer was going to sell me one for $75 but he never could find it -- even after I bugged him for six months.
I want to try one to see if the piezo pickup works better than the one on the Kent-Moore J-33300 units I have -- they're not rock-solid on the pickup via the injection line, they do the job but are a bit finicky.
Al: Do you have posted or might you send me photos of the piezo clamp adaptors for the Kent-Moore? I have one now but no clamp adaptors. Maybe the Seller still has them but doesn't know they belong with this tool. I did get the magnetic wand though!asavage wrote: SNIP
I bench tested this unit and finally got it figured out. It works!
I've never seen the 6mm pickup (for 6mm injector line diameter), only the 1/4" one. I used to know the suffix of the pickups. I'm pretty sure that the 1/4" pickup is J-33300-50, and I think I recall that the 6mm one is J-33300-25, but I can't find my notes and Google is not finding my old reference notes.
No, I don't know of a source for the transducers. I'd like to have a 6mm one.
I assume that the 6mm transducer would be more appropriate. I've been using the 1/4" one because that's what I have
and it does work, though as I mentioned it's not rock-solid on the signal.
I dropped a note to the Seller asking if he would look around his inventory for a/the pulse adaptor. I did get the harnass and the little forked terminal has been used (bent and marked) so the adaptor clamp may be around there somewhere .... I hope.asavage wrote:I assume that the 6mm transducer would be more appropriate. I've been using the 1/4" one because that's what I haveand it does work, though as I mentioned it's not rock-solid on the signal.
Also emailed Kent-Moore this evening. Hopefully they will respond otherwise, I'll call them.
Looking for the 6mm size.
Well, after some "clarification" (and I use the term loosely), I got a qualified response from Kent-Moore tools:philip wrote: I dropped a note to the Seller asking if he would look around his inventory for a/the pulse adaptor. I did get the harnass and the little forked terminal has been used (bent and marked) so the adaptor clamp may be around there somewhere .... I hope.
Sent by: Bob Schenk/ServiceSolutions/SPX
Date: 07/12/2006 04:47PM
Subject: Re: FW: J-3330000 "Tach n Time"
J-33300-25A - 1/4 " Pick Up Transducer - $132.10
J-33300-60A - 6mm Pick Up Transducer - $131.93
Thank You for your inquiry.
O.E. Technical Service
