720 from Russia
Vitaly
720 from Russia
Post by Vitaly »
I welcome all participants of this forum and immediately thank you for the useful, necessary and necessary information on the maintenance and repair of Nissan cars. My name is Vitaly, I am from Russia, Vladivostok. I have several cars:
- Nissan Datsun 720 1984 SD23 (RHD)
- Nissan Datsun 720 1982 Z16 (RHD)
- Datsun 720 1982 SD22 (LHD)
Every car has its own story and they are not perfect yet.
Glad to meet you!
SD22 MT
SD22 MT
Z16 MT
Z16 MT
gen1200 (11).jpg (272.34 KiB) Viewed 54569 times
SD23 MT 4WD
SD23 MT 4WD
Has thanked: 9 times
Re: 720 from Russia
Welcome, obviously I have a few diesel engines, what type of injection pumps do your diesel engines have, VE or inline?
Vitaly
Re: 720 from Russia
Post by Vitaly »
Thanks!
My engines have mechanical inline fuel pumps.
I found and bought an SD23 in the middle of nowhere. The previous owner used spare parts that were available at the time of repair. The engine starts and runs smoothly, but the original spark plug glow does not work. I am currently trying to restore it. I also have a donor engine, an SD23, and all the wiring from a Nissan Datsun ag 720, but I am unsure if it is functional. Please forgive my English.
SD23
SD23
wnQTWHeQ9icGgGc6ZQeJr4FajXo7iICm1M2Fi5FM7ruXpwB4YzHYgKs3py4VIvOElVI1I62TodxIxqVj-6zHFmztMFVK-AL_.jpg (432.51 KiB) Viewed 54502 times
SD22
SD22
Re: 720 from Russia
The first photo appears to have a VE type injection pump, the second photo appears to be an inline injection pump, the inline pump has 4 injection lines coming out of the top of the injection pump, while the VE has the 4 injection lines coming out of the back of the injection pump, I personally like the inline pumps because they last a lot longer(300,000+ miles) while the VE type do not last near as long.
The glow system is electrical controlled by a relay and glow plug timer, it is complicated, some people use a button on the dash and relay to warm the glow plugs(about a minute or less), most use a choke lever/cable to shut down the engine when things are not electrically working properly.
What is a "Nissan Datsun ag 720", not sure what "ag" is, is it a gas or diesel wiring harness?
This is a VE type injection pump.
This is an inline injection pump.
Vitaly
Re: 720 from Russia
Post by Vitaly »
Thank you for your clarification. Now I understand the differences between these pumps. The VE-type pump is installed on my restyled version. I assume that before 1983 (pre-restyling), inline pumps were installed on diesel engines, and after 1983 (restyling), VE pumps were installed. This is my assumption, and if I am wrong, please correct me. I rely on the cars I have and the Japanese catalogs, which I have several of. I will try to upload them here.
Regarding the glow plug system on my cars:
- Datsun 720 1982 SD22 - the original glow plug system works properly! This is very pleasing to me!
- Nissan Datsun 720 1984 SD23 (right-hand drive) - the original glow plug system does not work. The glow plugs are currently being heated using a button from the interior. I do not like this!
Additionally, I mentioned the ag720 earlier. This is the configuration of the Japanese Nissan Datsun 1985 Sd23, which is my donor car. Unfortunately, it also has a glow plug button on the dashboard. I purchased this car for spare parts. I am glad that it also has a diesel engine. However, this car was purchased as a non-functional vehicle, so I cannot determine which spare parts were in good condition. Currently, my goal is to assemble at least one working glow plug system from the two sets I have and install it on my Datsun 1984 SD23 4WD. (4WD is the term we use for the all-wheel drive system in Japanese cars). In Vladivostok, 90% of all cars are right-hand drive Japanese vehicles!
Please forgive my English. I type the text in my native language and then translate it using an online translator.
This foto my donor car Nissan Datsun AG720 SD23 1985
Vitaly
Re: 720 from Russia
Post by Vitaly »
22042025100710.pdf
Nissan Datsun 4WD Japanese catalog
(78.88 MiB) Downloaded 1368 times
22042025100504.pdf
(40.34 MiB) Downloaded 1281 times
Re: 720 from Russia
I have looked at all my photos and cannot find a glow plug timer(box inside the cab) that controls the relay that warms up the glow plugs, it is on the right side of my LHD diesel trucks right next to my passenger's right knee above the kick panel, do your glow plug timer?
I will decide if I will need take a photo after your response.
I have never seen a US version of a SD22 with a VE type injection pump, but I did import one that had the VE type injection pump from Australia when I was trying to turbocharge the SD22/SD25 engines, I finally figured out how to do it with the inline injection pump so there was no need to do a VE type conversion.
I do not know how to wire a glow plug timer box to work as a stand-alone system; does the button you use to warm the glow plugs use the glow plug relay?
Vitaly
Re: 720 from Russia
Post by Vitaly »
Good afternoon! I apologize for the long silence. There is good news! But first things first.
In your question, do you mean the dropping resistor timer or the glow control unit?
As I mentioned, I have two sets of all the glow system components, one from the donor car and the other from my car. At the moment, I am not sure about the proper functioning of each component.
To address this issue, I took my car to an electrician who previously worked at a local Nissan dealership. Additionally, I found pages from the repair manual for this system on this website. I also purchased a new set of Japanese glow plugs and two new glow relays, which I gave to the electrician.
After diagnosing the glow control unit, the electrician stated that one of the components was faulty, and the other was not providing a specific diagnostic signal. I did not delve into the details of the signal. The remaining components were functioning properly. As a result, the electrician replaced the glow plugs, relays, and created a new bus for the glow plugs. He also inspected the entire glow system wiring from the battery to the glow plugs. Now, the car starts, and the dashboard indicators are functioning correctly.
Additionally, the electrician repaired the heater, windshield wipers, and installed a relay regulator.
I will address the remaining electrical issues after completing the welding work on the cabin.
You also asked about the button in the cabin for warming the glow plugs from the previous owner. This button was present on both cars. The electrician removed it. Now, there are no unnecessary buttons in the cabin!
Fussible link
Fussible link
Glow plug control unit
Glow plug control unit donor car
New relay
New relay
Diagram glow plug system 720
Catalogue Hkt glow plug
Hkt glow plug
Hkt glow plug
Vitaly
Re: 720 from Russia
Post by Vitaly »
At the moment, the car looks like this. It's on a steady course, but there's still a lot of work to be done. I've started learning metal shaping.
Re: 720 from Russia
Is that white 4wd RHD a diesel? SD23?
Good to hear you are making progress.
Vitaly
Re: 720 from Russia
Post by Vitaly »
Good afternoon! Yes, that's right, it's an all-wheel drive car, the SD23.
Thank you! In any case, I will cover the continuation of work on all my Datsuns in this thread.
Re: 720 from Russia
I have only heard of one 4wd Nissan 720 diesel in the USA, and it came from Canada, I do not remember if it was RHD or LHD, the rest of the 4wd trucks were made by the owners themselves.
There are lots of them 4wd diesel trucks in Australia but I do not know if they had SD22 engines or SD25 engines.
I actually with my own eyes looked at a SD23 for sale in the city I live in, but I did not know enough about these diesel engines to buy it at the time.
I modified this truck to give me more leg room, it is a 1969 Datsun 521 kingcab now, it has a Turbocharged SD25 engine, it is my daily driver.
Here is the engine compartment, it is very tight, there is not much room left in this engine compartment.
Vitaly
Re: 720 from Russia
Post by Vitaly »
Good afternoon!
There are a lot of Japanese right-hand drive cars in the Far East. Most of the Japanese 4x4 cars (Nissan Datsun D21/D22, Nissan Patrol/Safari, Toyota Land Cruiser/Hilux, and others) have diesel engines. According to the information in the Japanese original catalogs that I have, the Nissan Datsun 720 had SD22 diesel engines until 1983, and after 1983, it had SD23 engines. This includes 4x4 cars. For example, I will attach some photos of 4х4 Diesel 720 cars from Russia. This applies specifically to Japanese cars. It is not uncommon for us, and it is even a common situation.
Previously, I had a bookmarked link to European Datsun 720 catalogs, but unfortunately, I cannot open it now. Most European websites are blocked in our country. There were various European versions of our cars. However, I do not remember specifically about the 4x4 diesel versions.
I can only speculate about other manufacturers. Wikipedia's Datsun 720 section provides information about production in countries other than Europe and Japan, such as the United States, New Zealand, Thailand, Canada, Greece, and Mexico.
Your car is quite interesting! Did you enlarge the cabin yourself? Is it a custom KingCab project? We still have SD25 engines!
1982 SD22 4x4
1982 SD22 4x4
gen1200 (14).jpg (73.7 KiB) Viewed 54007 times
1985 SD23 4х4
1985 SD23 4х4
SD23 4х4
SD23 4х4
1984 SD23 4х4
1984 SD23 4х4
Re: 720 from Russia
Yes I made my 1969 Datsun 521 into a kingcab, I needed more legroom, I bought a not running truck and made it into what it is today, I did another truck also, it took around 4 years to make that white one, it has a gas engine.
So is the white 4wd with a SD23 a drivable vehicle?
It appears to have functioning headlights and appears you might have backed it up to where it was parked when the photo was taken, I had a 1953 MGTD with fender mirrors, I did not like them, I put another mirror on the front windshield frame so I could see better.
There are 3 components in the diesel engine with an inline injection pump, there is the DPC module, the glow plug timer and relay it controls, it also has an injection pump controller, this moves the injection pump from the Off/Start/Run positions, you have to have oil pressure for it to move, it will not work without oil pressure, I do not know how the VE type injection pump system works other than it has a fuel electric cutoff to shut it down, I have never seen a stock one, I believe the Nissan diesel trucks started using the VE pumps after a certain date in the USA.
Vitaly
Re: 720 from Russia
Post by Vitaly »
Hello! You're just as much of a pickup truck fan as I am. I counted four cars in your parking lot. Your Datsun 521s are impressive! Great job!
I also have a white Nissan Datsun D22 pickup truck with a KA20DE engine and rear-wheel drive. It's my daily driver! I've put a lot of work into it, including replacing the carburetor engine with an injection engine. I've also done a lot of work on the body and overall styling.
As for my other SD 23 4WD pickup truck, it's already in good working condition. I've fixed the rear brakes, front brakes, parking brake, installed power steering, repaired the 4WD system, and replaced all the suspension components, including bushings, silent blocks, and shock absorbers. I've also replaced the spark plugs and repaired some of the electrical wiring. I'm currently working on repairing the floor, which is a common issue with Nissan vehicles. So, you can say that this truck is almost ready to drive. It had factory-installed mirrors in the fenders, so I decided to keep them.
I can't say much about the VE-type pump's operation, as I haven't fully understood the system. However, I assume it has its own control unit.
I also have a question for you. How similar is the Datsun 620 chassis to the 720 chassis? I have an insane idea. I want to attach the fenders, hood, doors, front bumper, dashboard, and steering wheel from the 620 to the 720's cabin. I have all the necessary parts.
My Nissan Datsun D22 today
My D22 in 2018 year
My D22 in 2018 year
