Greetings and an SD22 Lift Pump ?
Barkeywayne
Post by Barkeywayne »
Hello all, new owner of a Chrysler-Nissan SD22PU engine here.
Just acquired a Chicago Pnuematic CP185 air compressor with an SD22 Nissan diesel installed. This is a Chrysler CN4-33 variant.
Have been trying to get it running and am thinking it may need a new lift pump. It is a mechanical diaphragm-type pump with an inverted glass fuel separator bowl, as pictured.
Was wondering if anyone had any idea where I might source this pump or even a rebuild kit for it? I can provide any other info if you need it.
Any ideas would be greatly appreciated, thanks!
CP185 Compressor Lift and Injector Pump 03-18-2026.jpg (251.99 KiB) Viewed 41520 times
CP185 Compressor Engine ID Tag 03-18-2026.jpg (327.73 KiB) Viewed 41520 times
Chicago Pnuematics CP185 Air Compressor
Chrysler-Nissan SD22PU (CN4-33) Diesel Engine, Serial #112529
Southwest Missouri, USA
Has thanked: 9 times
Re: Greetings and an SD22 Lift Pump ?
I am not familiar with this part, it might take some time to get a response, you could try asking a forklift business or a diesel injection service place, they see all sorts of stuff.
Barkeywayne
I have spoken with a local diesel injection service and a place that specializes in foreign gas and diesel engine repair in general. I will see what I can find out from a forklift service.
The injection service told me the injector pump (Nihon-Cav brand) was looking for 3-7 psi on the diesel supply line from the lift pump.
My plan is to find a complete OEM-type replacement mechanical lift pump or a rebuild kit for it...if I can't find that to convert to a low pressure electric fuel pump to replace the mechanical one.
Thank you for your reply waynosworld.
Every lift pump I have ever seen does not look like that, there is no glass involved, the only thing I have that has a clear housing is my pre-filter on my firewall with its own primer, the SD22 has a lift pump on the side of the injection pump itself that is run by a lobe on a cam, it also has a primer, it looks something like this in this photo, this injection pump is from a boat I think but i do not know for sure.
This is our SD22 lift pump.
Barkeywayne
I have seen your type of integral lift pump on that injector pump (Kiki?).
My SD22 has the Nihon-Cav injector pump and an outboard lift pump. And it seems the CN4-33 Chrysler variant also indicates marine usage. Not having much luck finding any parts yet but I do have a couple of leads.
The search goes on, thanks! 8)
