'82 Maxima Diesel A/T (drive) Flex Plate
'82 Maxima Diesel A/C condenser
'82 Maxima Diesel complete Air Filter housing with throttle body assy.
'82 Maxima Diesel molded rubber intake-hose, excellent shape, no cracks
'78 ZX 280 flywheel
Pick-up in Vancouver. Pre-paid shipping possible.
Misc. Nissan Parts, free to take
- dieseldorf
If the MT flywheel is for the LD28, I want it. Probably some of the other items too, but I want the flywheel. Did I mention that I want the flywheel?
I have to go for some training out of town. Some of the nicer joints like to charge an arm and a leg for internet access. If I run into that scenario, you may not hear from me for a few days, but I want the flywheel.
I think I want one of the fuel filter/primer heads. I can't recall if the knob can be removed . . . yeah, it can. So I can use yours with the broken knob. Mine doesn't pump anymore.
On the flexible rubber intake elbow . . .
Mark's Sedan needs one, but it's got to be for an '83. Pictured above is an '82. '83 is somewhat longer. Holding the '82 hose above the '83's, it does look perhaps 3/4" too short where it needs to meet the air filter housing's EGR throttle.
$80 for that MT flywheel is too low. If the teeth are good and it's resurfaceable, start at $130.
- dieseldorf
Both rubber intake hoses are from an '82 Maxima.
I can't find any reference in the FSM to machining the flywheel, minimum thickness, or anything like that. Not in the clutch or MT sections anyway. I wonder if there is a minimum thickness number on the flywheel? If the teeth are good and there is some way to gauge the remaining life in the flywheel, it may well be worth more than $80. I don't know. I'm still interested, but I don't want to steal it...
Chris, I haven't heard from you about this . . .
I'm heading to McMinnville on 13Sep for the annual cider pressing party, perhaps I can swing by on my way there or back?asavage wrote:I think I want one of the fuel filter/primer heads. I can't recall if the knob can be removed . . . yeah, it can. So I can use yours with the broken knob. Mine doesn't pump anymore.
